- Year
- 1997
- Vehicle Model
- 80 Series
- Location
- Atlanta, Georgia United States
- Mileage
- 312000
1997 Toyota Land Cruiser. $15,000.00
40th Anniversary Limited Edition No. 2733
Triple locked (new OEM factory lockers)
Part-time 4WD conversion
VIN JT3HJ85J6V0171590
3 Owners
GA car no rust
Mileage: 310,000 (body)
240,000 (engine)
NEW PARTS AND MODIFICATIONS INCLUDE:
Engine:
head gasket p.o.
new gaskets
intake cleaned, (no PO401 code)
new radiator
new A.C. compressor
new starter
new power steering pump (fluid changed to ATF)
new plugs/wires/distributor
new fan and fan clutch
PHH done (disconnected rear heat, unit still installed)
Transmission:
Flushed and filled with Toyota ATF
Trans cover skid plate
Transfer Case:
Locker rebuilt
Part-time conversion (Marlin Crawler parts, worked performed by ACC Toyota Atlanta)
I don't know if it makes a difference in gas mileage but big difference in throttle response.
Drive shafts new U Joints balanced
New motor and trans mounts
Axels rebuilt
New OEM lockers
Extended breathers
Aisin hubs
New brakes all the way around, green pads
Extended brake lines
Toyo open country 315/75/16
Original 40th wheels
Suspension:
4" lift (heavy)
OME Springs heavy
OME 10mm Packer
OME Shocks
OME Steering stabilizer
Slee Caster plates (welded)
Slee Front and rear adjustable pan hard rods
Slee Rear adjustable upper control arms
Steering drag link
New tire rods 555
New body mounts
Message for details!!
Quote Reply
Report Edit
M
Written by
JoinedAug 14, 2016Messages32LocationAtlanta GA
3 Owners
GA car no rust
240,000 (engine)
Engine:
head gasket p.o.
new gaskets
new radiator
new A.C. compressor
new starter
Transmission:
Transfer Case:
Locker rebuilt
Axels rebuilt
New OEM lockers
Extended breathers
Aisin hubs
Suspension:
4" lift (heavy)
OME Springs heavy
OME 10mm Packer
OME Shocks
Steering drag link
New tire rods 555
New body mounts
Quote Reply
Report Edit
M
Written by
Moonrush6755
51 · From Atlanta GA- Messages 32
- Reactions 3
- Points 0
Moonrush6755
- May 26, 2021
- Thread starter
- Add bookmark
- #2
