For Sale Atlanta: 1995 RHD 80-series, Japanese import
Year
1995
  1. 80 Series
Array
Mileage
156525
Color
Black
Listed at $20,500. The timeless 80 series Land Cruiser - this is a very low mileage (156,525 in miles, although odometer is in Km, so 251,900 on the dash), 1995 right-hand drive, with no lockers. It was imported from Japan in 2021, I'm the second owner since then. I had plenty of work done on it below, never took it off road in the year that I've owned it, unfortunately. AC blows extremely cold, zero mechanical issues. The driver side fender flare needs some paint, a taillight is cracked, and there is a small dent in the driver side rear bumper. Other than that, paint is pretty clean, rides like an absolute dream. Could be a daily driver with many years left with such low mileage. Work done in the last year:- Coolant temp sensor replaced - Radiator and hoses replaced- AC tensioner pulley replaced - Idler pulley replaced- Rear main seals redone - Front crank seal redone- Oil pump seal redone- Engine temp and oil pressure assembly replaced- New 33” tires- 2” lifted suspension and springs installed to replace old 3” lift- AC recharged- Removed window tint- Clutch fan assembly replaced- Lock up solenoids on transmission replaced- Torque converter, seal, flex plate bolts replaced- Upper oil pan seals replaced
