We have an excellent condition Black Series Patron for sale. We just bought this from the original owner in the spring of this year. I upgraded the battery to a Lithium Ion that can power all the accessories with ⅛ the weight. We went one one camping trip this year up to the Sierras and loved it. The reason we are selling it is because we are starting our own business and we need the capital. It is the dream trailer that I wanted but we need to make the sacrifice to pursue other dreams. Below is a list of all the amenities.
My name is Ryan. Feel free to call or text: eight05-45eight-fourfor14
Electronics:
Brand new 100 amp Lithium Ion battery ($870)
120 watt solar panel briefcase with 20 ft charging cable
Interior LED lights
1000 watt inverter
Full control panel with accessories switches
Suspension:
Fully independent dual shock axles
Limiting chain on both axles
Parking brake on both wheels for ease of set up
Electric trailer brakes
Aluminum 16 inch wheels
It has a low center of gravity for towing on or off road. I can take more pics if interested. I bought a few bins to go in the pull out storage areas that will go with if you
Incredible totally stainless still kitchen Sink and 3 burner cook top.
cutting board and storage in and around kitchen for supplies.
Led lights though-out.
At the lowest point it sit at over 22" of ground clearance.
Sleeps 4-5 People.
Comes with 2 extra full size spare tires
The main part of the trailer takes less than 15 min to set up solo. (after doing it a few times)
Tough Enough for the Australian outback
TONGUE WEIGHT: 300lbs
WEIGHT: 3432 lbs
GVWR: 4,400 MAXIMUM TRAILER CAPACITY
HEIGHT: 5.25 ft
LENGTH: 17.4 ft
WIDTH: 6.16 ft
MAIN FEATURES:
SUSPENSION:
-Independent suspension: dual shock absorbers per independent arm and coil springs
-limiting chains
CHASSIS:
Galvanized chassis with RHS 100x50x4mm made in one continuous piece to rear ensure the draw bar is unbreakable!
-(X4) Heavy Duty lockable & adjustable Stabiliser Legs- (wind down spindle supplied)
-Two rear rated recovery shackles fitted standard
HITCH: Black Series ADR Approved Off-Road “Polyblock” hitch- (vehicle attachment included.)
-Jockey Wheel: 10” swing-up & lockable
-Light Connection Plug: 7 pin flat plugs ADR dual safety chains
INTERNAL SETUP:
-Table with surrounding couches, with front and rear bedding areas.
-REAR slide section turns into a second bedroom while you keep the lounge area
WHEELS:
-(X4) 16” Black Series alloy wheels (6 stud Landcruiser Pattern) with mud terrain tires
BRAKES: 12” Heavy Duty electric brakes assist setup
CONSTRUCTION: Galvanized frame fully enclosed, fully welded, bonded and sealed for maximum strength
*Finish: Enamel baked paint finish
*Internal Finish: Modern wood finish with marine carpet
-Undercarriage: Deadener coating used for maximum protection
FRONT STORAGE COMPARTMENT
-(2X) 5gal jerry can holders
-(2X) 20lb PROPANE bottle holders
Gas Lines: from regulator to kitchen and back for outdoor shower
Stainless SLIDE-OUT Kitchen:
-Large sink,
-LED Light
-electric pump and faucet
-Stove and large fold out bench top
-Extendible table extension
Water Tank: 26 gal food grade stainless tank with stainless protective cover and lockable filler cap
Lights: LED Fully submersible tail lights, number plate and clearance lights
️ELECTRICAL SYSTEM:
- 1 Deep Cycle lithium ion battery 100 Ah with 12V sockets and equipped with a 50 amp anderson plug
-portable solar panel
Stone Guard: Modern design stone guard covered in deadener
Huge Tool Box with large drawers for generator or fridge. also includes a built in pantry, ventilation fan and light.
BOAT/ GEAR Rack
Dual spare wheels on rear mount (Gas strut assisted)
️TENT SPECS:
-Setup is made easy with two winches and a lightweight aluminum lid
-A Collective 194 sq ft of living space
*Hardstand Section: 16.0 (ft) X 6.0 (ft)
*Annexe Section: 15.4(ft) x 8.2 (ft)
SLEEPING AREA/ MATRESS:
-Quality mattress included QUEEN SIZE
-BENCH SEATING that converts in to an extra queen sized bed
Electronics:
Interior LED lights
1000 watt inverter
Suspension:
Sleeps 4-5 People.
WEIGHT: 3432 lbs
HEIGHT: 5.25 ft
LENGTH: 17.4 ft
WIDTH: 6.16 ft
MAIN FEATURES:
-limiting chains
-Large sink,
-LED Light
