I think you will get a decent tire from any of the major brands and, as long as you are not obsessive, probably wouldnt know the difference between them. If you are nit-picky, then you will probably see differences and one tire may perform better for you and your driving style/situations better than another.
That does not mean that lesser known brands make bad tires though. Look at Kenda with their Klever line. They are getting reviewed really well and are pretty cheap in comparison to similar tires from BFG, Goodyear, Toyo, etc.
Just like oil and air filters and all the other things people debate about, it really needs to be a personal decision based on your use case about which tire you land on if you want what performs the best for you.
TaxesGive me an example of something that you “don’t get what you pay for” with the exception of boutique fashion garbage.
What you pay for is brand value + cost of manufacturing.Give me an example of something that you “don’t get what you pay for” with the exception of boutique fashion garbage.
Breakings this down from two perspectives:
1. Casual Users
I would argue that perhaps for this audience, that actual tire qualities and performance matter little. I can see an argument for tires as a commodity. Where paying more for a tire is just to feel good (e.g. brand) as they can't discern qualitative differences. Other than immediate NVH impressions. And possibly incidents where the tire is used in situations outside of its intended use, or the performance envelop is exceeded, and is a wake up call. Even then, some probably wouldn't attribute it to the tire? I'll put my wife in this bucket, but perhaps 90% of the population also falls here. The point is that most every tire is capable of general commuting use.
2. Performance users
This is a different breed of users. Either those that regularly push the performance of the tires. Or utilize them in more extreme use cases where design intent of the tire matters. I've used performance tires for race and off-road. The characteristics of tires vary significantly, even within categories. A/T tires are probably some of the hardest tires to design because of the "All" in All Terrain. For those that actually use these tires in all the very different ways they can be used, there are pretty huge characteristic differences. And that's what makes it so hard to compare, as everyone has slightly different use cases that inform their impressions. Commuting is a poor way to discern differences. The Instagram test is a great way![]()
