Those are the alignment guides for the steering cross shaft. When those marks are lined up fore & aft with the housing, the shaft is at it's center position. My steering box is off right now (I'm painting it) and I just checked. Ideally, the pitman arm should be installed in a straight line with those marks if the rest of the steering system was originally set up that way.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
