Are OEM rear axle shafts still being produced or NLA?
Kabanstva
Illinois
I want to get spare rear axle shafts.
It’s a 1994 (11/94 build date)
NO factory triple lockers
Has ABS brakes
I looked it up by the VIN and Serra Toyota of Decatur is showing them as available but in the diagram it’s showing a semi-float axle so thsts throwing me off.
Would love to know the actual part numbers.
Thank you.
Look it up on partsouq. You should be able to get a part number there and see if it is available through your dealer.
Unfortunately, this is one of those times when the desert warehouse will fail you. PartSouq only lists what they have, not what is being produced. Further, their EPC is wonky. It lists ABS as *66, so if you don't know that, you'd be lost.
Send an email to Dave Stedman. He'll have the correct answer.
Post back here when he lets you know; I have the same Year/Month truck. That would be good to know info.
It’s good to have spares! 😋🤙
Cheers
RH: 42311-60110
LH: 42312-60090
Both are readily available.
I have slightly twisted splines on both sides. Are the locked versions still available?
While I still miss ARBs, it's more than likely the reason I get a frowny face whenever I try to use the rear locker.
No doubt
RH: 42311-60110
LH: 42312-60090
Are these old part numbers? I’m not getting any results searching these through any US Toyota dealers. Only get a couple random hits from Japan if you Google search these numbers .
Well, the table has flipped. These were available as recently as 2 months ago.
42311-60100: Discontinued
42312-60090: Discontinued (but superseded)
42311-60110: Discontinued (but superseded)
42311-60110: --> 42311-60111 (3 available)
(Heritage Parts program part)
42312-60090--> 42312-60091 (seem available from overseas)
I appreciate the info sir.
When I type in my vin number on Serra Toyota website who I’ve bought a lot from before it shows this part number for the rear LH axle:
42312-60080
Is this incorrect part number (94 LC no factory lockers) not sure if it even makes a difference.
42312-60080
That's for a semi-float axle with drum brakes.
42311-60111 and 42312-60091 have larger diameter sealing surfaces and require 90310-36003 shaft seals to go with them. The original seals, 90310-35001, are too small.
42311-60111 is for with difflock but it will work in a non difflock.
