LukeZero
Deeply Confused
I started to put an ARB Air Locker in the 14 bolt full floater in the back of Bugly (Butt Ugly Cruiser) over the weekend. Followed all the directions. Reused the 5.13 'thick' ring gear. Used new carrier bearings and races. Didn't touch the pinion depth. Drilled and tapped the housing for the air line. Put the carrier into place and it won't turn. Seems to be some interference with the housing. ARBs literature suggests there are some housings that will need to be 'clearanced' to allow the carrier to fit.
So I study the picture, pull the pinion out, stuff rags into the axle tubes, get out the angle grinder and go to town.
THREE TIMES!!!
Reinstall the pinion, reinstall the carrier (fxxxers heavy, especially when the differential is tipped way up because of the short rear driveshaft) and find that I haven't ground the part that hits yet.
Did I mention that I did this THREE TIMES?
Anyone have a good picture of what a 'clearanced' housing looks like inside? Maybe if I see what the hell it's supposed to look like- I can get this right and reassemble my rear axle.
Thanks for the help,
Luke
PS. This is posted over on Pirate also- just looking for as much info as I can get.
THREE TIMES!!!
Luke
