ARB Air-Locker
Hey,
I had an ARB locker installed a month or so ago by a reliable shop. My question is...
Has anyone else who has an ARB locker had oil come out of the pressure relif valve located on the comprssor???
TIA
N
Happens once in a while...
Check your axle breather located on the top of the axle housing (passenger-side) of the differential...
It can become clogged and allow pressure to force oil back to the solenoid...
:beer: dude :)
If your breather is clear then there is a real good chance your seal housing O-rings are bad. How many ARB's has the shop installed? The O-rings should be coated with assembly lube when installed to avoid problems and longevity.
