- Thread starter
- #841
JPs are plastic and are more portable. The internal components are very similar between the two.Any preference in the JP vs the current VL line? Anyone go from JP to the VL?
Luis
Right now I am leaning towards the TR because of the portability factor; the wheels are a game changer.
As far as power consumption, I am running a series of test that will give everyone insight into that. Today’s test ended after about 21 hours. The first 33% lasted like 15 hours, and last 66% lasted only 6.
Why the big difference? It was in direct sunlight for the latter part of the test. So now I’m back to the drawing board as far as designing a more controlled test, where the conditions are easier to replicate for future tests; otherwise the comparisons between tests will not be accurate/fair. Today’s test revealed that it’s not the Eco vs Max mode setting that caused the difference between 26 and 20 hours results, but rather likely because the fridge was under my awning in one test, and not for the other.
Prolonged direct sunlight makes a vast difference, so I would recommend setting up/parking in the shade when you are concerned about battery capacity.
With that said, anything above 17 hours means we will average less than 10W continuous... which is impressive and very promising in terms of incorporating it into a project I am working on for everyone.
