Do you have any pics of these totes on your rig you can share?I am running 285/70r18 ridge grappler with no issues. But I want something less aggressive for highway use during spring/summer road trips.
Did you decide to give 295/70r18 a try?Are any of you running a 295/70/18 on your lifted 200? If so, which lift are you running and what are your wheel specs? I am very torn between 285/70/18's and the 295's, but there are a lot more options in the larger 295's and the prices are better as well.
Lol, nice. Are you going Ko2 or something else? I was coming out of the gym and saw a new Ford Tremor(looks good) and it was sporting 275/70r18 General Grabber APT and looked pretty good in person but they look a little skinny. It’s more obvious with the larger open wheel wells of the ford where the 200 may hide it a little better. Conti-terrain contacts and Revo3 are still on my list.As soon as it's no longer the wife's daily lol.
You will need between a 3/16”-1/4” nut welded on. I can’t foresee losing much turning radius and if you’re running a 295/70r18 it won’t hit the sway bar anymore. You can epoxy the nut on to test how much turning radius you’d actually lose before welding it on. If you have access to a dirt lot, bring a rake, broom for a nice track circle and measure before and after, then report back.Has anybody tried welding something to the driver side turn stop knuckle to shorten the turning radius keeping the tire from making it far enough to hit the kdss?
Hey so how much actual lift are you running? Im having Dobinsons set up some struts and need to know how much to run. 2"? 2.5"?
Stock suspension or with coil spacer??
I saw your post in another thread. A lift or coil spacer has zero impact on running larger tires. All the coil spacer does is set the neutral ride height of the truck. The tires still have to clear through the full suspension cycle and lock to lock.Stock suspension or with coil spacer??
So.. can I fit 285/70s?I saw your post in another thread. A lift or coil spacer has zero impact on running larger tires. All the coil spacer does is set the neutral ride height of the truck. The tires still have to clear through the full suspension cycle and lock to lock.
The work is the same whether or not you have a lift.
YesSo.. can I fit 285/70s?![]()
Have you seen @tbisaacs thread?This thread fell back a bit, anyone jump on the 295's or have any updates?
I want to pull the trigger on these in a bad way!
Westcott lift, UCA's, and 1.25 wheel spacers@stevopike
Looks awesome! That's what I'm after. Supporting mods?
How's the clearance on the kdss bolt?
Thank you sir!
