Simply running reverse wrapped eyes can lower you 2" , depending on the diameter of the spring eye.
Example of reverse eye...
Are these always custom springs or did they come stock on some vehicles?
this pic shows the issue with frenching the shackle. The shackle has to be made longer so the gain is minimal if anything. A spring over with a flat spring can run a pretty short shackle if the bushing tube is placed on the bottom of the frame. A short shackle won't clear through a range of motion, in many cases, when it's frenched through the frame. The other consideration is whether the centerline on the frame is the correct centerline of the spring. Many hangers are offset because the frame rails are not parallel right and left so moving the hanger fore and aft along the rail may change it's position relative to the center of the frame rail.
This is probably a valid point. The 3/4 HD springs I have for the back will likely be anything but flat. I could see where if I frenched int the hangers I would lose a great deal of available motion. That is is I am understanding you correctly.
I haven’t but am running rear 63s. What size tires do you want to run and what are you type of terrain are you going to drive your 60 on?I know this thread a few years old,, Has anyone since used these Ruff Stuff frenched 63's hangers? I was thinking of getting them to run a pair of 63's as low as possible.
They were stock on many vehicles especially older trucks. A lot of hotrod/roadster guys do this to lower their truck. Rubicon Express sells a set of these specifically for spring overs on Jeep Wranglers. They are easily researched on Google.
Berlin eyes are considered the strongest. I used those on the Mohave spring design. They will also drop you a little, about half what the reverse eye will.
You especially find the Berlin eyes on very heavy trucks, over the road, cement, etc
berlin eye
here's a quick and easy read
http://www.eatondetroitspring.com/wp-content/uploads/st101.pdf
