Anyone got a transmission jack that I could borrow?
yotadude520
Wingin' It
Moderator
The Wild West
Looking to swap in my H55F and figured I'd check here before I go to Harbor Freight and buy one - located in Tucson.
Thanks!
I do, but in N. Phx. Probably cheaper to go the HF route than I-10.
Have a 2,000# in Northern Arizona. Really need a good transmission jack for the H55F and split transfer case. Engine hoist thru the door depending on the vehicle.
I appreciate the offer, but definitely right, I'll just rock the HF version and get it done!
It's on my FJ60, wish I could get it through the door like a 40!
I have the 450# scissors jack. Bought many years ago when it was only $40. Worked okay lifting a bull bar on my FJ62. I have bolt on sliders for a 5th gen 4Runner install only as needed. Not sure I would attempt an H55F and transfer case with it. I have no experience with the 800# transmission jack. I picked up a 2,000# transmission jack from a member a number years ago. I keep it up north because it stores better in a milder climate than a hot garage in the valley for the oil seals.
I used the HF jack for my H55 swap, worked ok, doesn’t quite instill confidence tho.
Did you get the 800lb version or the little scissor jack contraption?
I ended up getting a used 800 LB one on CL for $120.
