Anyone fit 35 inch tires on the LX600?
Looking to put on 315/70/17 (~34.5 Inches) tires just want to know if its possible or if there is anything to look out for thanks.
Wheels are 17x7.5 +30mm (Might be +25mm)
dont do it. the engines are blowing up with stock sized tires. last thing you wanna do is overstress the engine even more with 35s.
Hyperbole much?
Yes I own a 600. There are things I like and dislike about it. Would you like a list, since you don’t own one? Looks like you own an older GX which is just fine.
If you want to have an intelligent debate I am down for it. 409hp and ~500ft/lbs torque is plenty to turn a 35” tire especially a light weight one. Side effects won’t be it ‘blowing up’ but rubbing, loss of mpg/acceleration, programming of shift points off etc.
And yeah they look goofy with 35s. Getting any negative offset past the edge of the fender is a goofy look risk too. Stick with a metric around 33”.
I’ve never owned a GX. Not sure where you got that
Yeah I decided to keep the 285/70/17 not worth going up to 35s just for style points imo.
Not sure if you've seen the truck Dissent has been working on. Says minimal cutting/trimming, but they did remove the whole stock front bumper 😂 so I'm sure that helps. There are a few more updates from him later on down that thread.
