antifreeze leak inside vehicle
I have a 1996 and when I crank the truck up it leaks antifreeze inside the vehicle just besides the radio the problem just started. it is a steady stream of fluid also. need help desperately:confused:
heater core without a doubt. get some pigmat absorbent material or similar and lay it out until you can fix it., diapers also work well. Try not to get much of that in your carpet, takes a long time ti rid of the smell.
Heater Core is probably the issue. But do check your hoses and connections at the firewall under the hood to the heater core to make sure you do not have a leak from them that is getting in the heater box before going thru the h e _ _ and expense of replacing the core...
X2 on the smell. If it's Toyota coolant, and it's been in there since '96, it's gonna make your carpet smell like stale menses.
