Another thread of replacement of light bulbs in the control panel and the climate control unit 1994 LC. (3 Viewers)
Israel
Hello, I searched and searched for two days and did not find. I am looking for a list of all the types of bulbs needed in the control panel and the climate control unit and dash. I found a lot of threads that talk about replacement of by LED . I would like to replace with OEM bulbs not LED with the possible exception of the rapidly burning D.
I have to order everything in advance from abroad and it takes time, so I need a list of everything in advance because if I lack a bulb I will have to put together everything to order and dismantle everything again
Thank you very much for your help
Check this thread out its a mix of old and new but it should have what you're looking for.
Thanks, I have seen this I would like to order bulbs from Toyota not leds
I think I have the bulb part number at home in the cruiser, mine is a 94 and I replaced the shifter light, cig ashtray, and I had one in the temp cluster but it started working again. I’ll get it tonight if you still haven’t found it. The bulbs have little green covers
1927256
Burning D is the worst. I’d make fixing that priority 1.
