Build Another Texas LS1 Swap
To add what TT mentioned, I have a bout 1/4" between the DS and the pan. So if I build a smaller diameter DS I may be ok. I'm researching how small of a diameter I can go with by using thicker pipe like DOM instead of DS tubing. Maybe I'll make one out of an axle shaft. :grinpimp:
Excellent info you are putting together here. <Subscribed> Looks like its coming together good!
E.
Hmmm.... That's a good idea. Where would be a good source?
Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
something like this flipped the other way
So in on this!!!! I am in love with the LS platform and the Landcruiser platform. They need to mate.
Whats the dollar you are figureing for the entire deal. Minus labor.
Wiring...
Got the wiring harness on. It took about 45 minutes after I laid it out to figure what went where. Here is a pic of the harness.
Starter Wiring
Today I worked on figuring out how to wire the starter.
Key is in the On position: The circuit runs 8v from the switch into the gear indicator on the transmission. 2v is seen at the starter.
Key is in the Start position: 12v goes down the same circuit and if the gear indicator is in P or N, it passes through to the starter.
So I took my old engine harness and cut what I needed and created a harness that will engage the starter and feed power to the computer. Note the IH1 connector is the point where the engine harness interfaces with the gauges, dash, and ignition switch. It's behind the glove box.
Pics: Wiring diagram, IH1 connector, harness.
Hi Jeff we are running different ecms and years but you may want to double check this. My gm harness takes the signals, key on 12v+ and crank key position at the GM ECM. It sends those through the GM harness to the starter. so the IH1 wires I sent to the GM ecu first and never directly hook to the starter. My GM harness had it this way.
There is about no room to work up by that IH1 connector! Wait till you have to fish wires from the IH1 to the drivers side it sux!
Kirk
Kirk
After I came inside I was thinking about the how the gear indicator works on the 4l60 and am going to look into wiring harness that came with the tranny. The 8v in the starter circuit when the key is on was unexpected.
I hope I do not have fish that connector over there. It looks like it would take a delicate amount of C4!
Wish I knew more about my harness to help you wih this... But I bet my old ass truch didn't have the voltage change anyway :lol:
Honestly if you are the only driver why dont you just skip going through the tranny all together? Also you may already have neutral safety and you dont know it. I think your gm tranny controller sends a signal to the gm ecm already. I know my gm setup does so I am going straight from IH1 to the gm ECM.
Mine starts in gear... Found out the hard way
