Hey guys so just notice this issue that started from yesterday.
1st time I noticed it I was getting on an interstate ramp, the ramp goes down but the interstate slights goes up hill from the ramp. Anyways I noticed a shuttering/shuddering (whatever you call it) while accelerating on the hill. The car was just warmed up then. I didn't notice a drop in RPM at this time. Initially thought It can be transmission problem. This is a LC 2000 with around 165k miles on it.
2nd time I noticed it today in the morning right after I turn the engine on. It shudders when cold initially. But after driving it to normal driving temp I feel it again 2 time again, once somewhat strong the other just a hint of shuddering. Certainly not how I felt it in the morning. Again the RPM did not drop, it just shudders that's all. Drove it another 2 times today, and it ran perfectly.
I have no check engine light come on at any time and checked they where no fault codes.
BTW reading some other forums on this, I did change my gas to another (cheaper) gas company. It could be just bad gas maybe? I didn't notice this issue ever before this. I could change my gas and see if that is the issue. I put in 87 oct in it. Would bad gas throw any fault codes?
So I am thinking the following -
Cause 1 - If its the transmission issue - What should I see?? I should see the RPM rev up or down right? Should I see any fault codes?
Cause 2 - If this is a coil pack issue - What behavior should I see? I should see fault codes here right?
Cause 3 - Bad Gas - What behavior should i see? I dont think i'll see fault codes here....right?
Cause 4 - Other sensor causing this behavior TPS/MAF/??
Cause 5 - Act of God - worse case change transmission - Hopefully its not this.
