Another Monstalined 80, lots of pics while she's clean!
Sacramento, CA
Well after an entire YEAR, my truck is finally painted. Hard to believe I started this project back in September 2012 after removing the flares:
I always knew I was going to use Monstaliner it was just a matter of picking the color and diving in. Ended up going with their newish "Sans Panties" color. I'm really happy with the way everything turned out. It's not perfect and was never meant to be, but it passes the 20ft test just fine. Texture is great and the finish seems very durable and rolls on very easily.
Since I'm sure folks will want to know, here's a list of tips and things you should keep in mind if you decide to line your truck.
- Prep, prep, prep. Don't try to save time here. Make sure the surface is completely clean and use lots of MEK
- MEK is no joke. Even using it outdoors will get you light-headed. This is a seriously nasty solvent. Use common sense.
- Make sure you have lots of light. Get some big halogen shop lights and aim them at the panel you're painting.
- You can't take your time while rolling. This stuff sets up FAST, even on a day that was in the 80s. By the end of the gallon it was like painting with oatmeal.
- 2 gallons is BARELY enough to do the entire exterior on an 80. I barely had enough to do a thick 2nd coat on the passenger side so the texture isn't as nice as the driver side.
- Buy lots of extra rollers. I went through 7 of them. As the paint sets, it gets thick and starts to tear off chunks of the foam while rolling.
- Have a set of tweezers ready to pick crap out of the paint.
- This stuff is messy, be ready for it ahead of time. Lots of plastic drop clothes and gloves.
- Having a helper is a good idea to remove the masking tape AS SOON as the 2nd coat is done. Otherwise it will set up and make it more difficult to remove after you're done with the whole truck.
- If you have the space and the tools, definitely spray this stuff on. Would make your life a whole lot easier. Rolling isn't hard, just very time consuming.
- Remove all the parts you can instead of masking them off. Takes more time, but gives a much cleaner look. Door handles for example. Pain in the ass to remove but I'm glad I did since I was able to separate the piece of black trim from the rest of the paint.
Now on to the pics! I used Rustoleum "Hammered Rosemary" for the bumpers, door handles and mirror base. I will mostly likely end up Monstalining the bumpers over in Desert Sand since I'm sure the spray paint won't last. But that's for another day!
You probably won't ever see her looking this cleaning ever again so enjoy it while you can :flipoff2:
Wow that turned out very nice.
I have decided to line mine when I get around to it.
Jose. Your truck looks dope!!!!!! Never knew it had vents on your hood.
That turned out fantastic!
And I second having good light. It can be really tough seeing how well it's covering without light directly on the panel.
That looks AWESOME. How did you do the mirrors, and did you do the door jams and under the rear hatch. If so PICS?
Thanks guys! For the mirrors, I completely disassembled them and separated it from the base. I didn't do the door jams, only what the paint covered through the cracks. For the rear hatch I painted a bit under, but not the whole thing. Here's how that looks
Nice work brother!!
Looks amazing, planing on de cladding my LX next year and going Desert Dune Monsterliner on it.
Would you suggest going with 3 gallons if you did it again?
I have the ability to spray but like the rolled texture (not as rough).
Great job.
Thanks! ^
3 gallons would definitely be too much. I think more like 2.25 or 2.5 would be safe so you can get 2 nice coats on the whole truck. But keep in mind I also did the lower half of my front bumper.
One nice thing about the San Panties color is that it matches the Commando Green color from the new Jeeps, so I could buy the touch of bottles of paint to take care of any chips in the future.
Thanks! ^
Thanks!
I may try and get it at the same time we do my Brothers HJ60 get 5 gallons and split one.
That's also why I like the Idea of the Desert Dune I believe it is the same colour that comes on Jeeps for easy touch up as well.
:cheers:
Looks good. Been planning on doing the bed of my truck with it.
Your attention to detail shows making it the nicest use of Monstaliner to date that I have seen.
Thank you sir, much appreciated!
Nice paint job! I'm thinking about pulling the carpet and painting the cargo area floor. You think the Monstaliner would work well?
Yeah it definitely will. I think the original intent of Monstaliner for truck beds and Jeep tubs. Lots of Jeep guys have been pulling out their carpet and lining the whole interior. I kinda want to do the same eventually since my carpet is starting to get a bit gross. But I need to see what wiring is down there, and how to hide it once the carpet is out.
Thanks! A truck bed should be a quick and easy project :)
I'm going to take off my remaining 3 flares soon and was going to Durabak the paint they covered as well as the rockers. The Monstaliner likes look a much better choice. Do you think a quart would cover the flares and the rockers below the doors?
