I'll start by saying I'm no noob when it comes to Toyota trucks and Land Cruisers, but this one has me stumped.
I bought a 94 FZJ two weeks ago tomorrow and when I went to pick it up it didn't want to start. I looked around and found that the intake hose was loose, reconnected it and it cranked and ran. After getting it home I took it for a test drive and noticed that it really didn't want to accelerate like I thought it should and it had a noticeable skip. Also found it to be pouring oil from the rear of the valve cover gasket so I decided to do a full tuneup on it while I was replacing the valve cover gasket.
So I replaced the plugs, wires, cap, rotor, valve cover gasket, cleaned the throttle body and it didn't "skip" anymore, but still didn't want to accelerate. It felt to me as if the TPS was malfunctioning because it would run out great at WOT, but didn't really want to accelerate anywhere between say 1/4 to 3/4 throttle.
So last Saturday I replaced the TPS with a known good used one and replaced the coil wire which I forgot to do when I was replacing the others. The truck ran like a top for a few minutes and then I noticed that when stopped the idle would start dropping slowly until the engine starting chugging and the RPMS would bounce until the engine finally stalled.
Fast forward to today. I have been searching possible causes here and have replaced parts until I am blue in the face and still have the same problems. Since the tuneup work I have replaced the TPS, AFM, IAC, ECM, fuel filter, checked and cleaned the engine grounds, replaced the battery terminals, and all the vacuum lines w/ the exception of the ones under the intake plenum. Jumping the diag terminals nets a constant flashing CEL which I understand to mean that there are no codes.
I am officially at wits end. If I can't figure it out in the next few days, I am going to drop it and my AMEX off at the Toyota dealer.
