When the trim is on does this sensor rest behind the little slots below the ignition?
Yep, that's the one!
my heater will make you sweat in sub freezing temps, my rear air gets so hot I can smell my carpet and my seats heat goes all the way up my mid back...
ahhhhhhh the 100 rocks![]()
Are you saying that you think something else should be connected directly to the pin you marked? Looking at your pic it looks like the white arm pivots with the shaft going into the plastic background and that the actuating arm for that is the metallic part going down to the left. Is that latter one not connected to something?
Its an artifact of the camera angle. The white arm is entirely independent of the pin I marked. There's a few mm of vertical clearance between the white arm and the pin. The pin is driven, which makes me think the arm may have failed here.
There is very little heat coming into the cabin, which looks like its due to an air mix door problem. That's how I came to be hanging upside down in the pass foot well looking at this.
