D
Docmallory
Guest
Hi all,
I just bought an amp (JBL, 150W 1 channel) and a sub (8 inch dual cone Cerwin Vega) for my cruiser. I need some advice on how to wire it up. I still have the factory deck and will likely have the factory unit for 5 more months. Then I can use RCA jacks, but until then I am forced to use a converter or the speaker level inputs on the amp.
My proposed plan is to place the amp in the area where the factory sub and amp are currently. The sub will be in an enclosure box in the cargo area. I plan to run heavy gauge wire for the power supply to the new amp. My questions here are:
1. Should I run the power lead directly off the battery, or since the positive terminal is getting crowded with accessories, is now a good time to add an auxillary fuse block and run off that?
2. Specifically where should I run the hot wire to get back to the passenger side of the cargo area?
I also figure I could use the remote switched power lead that leads to the factory sub amp, and I could run the speaker wires that lead to the factory sub amp to the speaker level inputs on the new amp (until head unit is replaced later). I seem to recall these speaker wires do not run through the main amplifier for the head unit. People who know, please correct me if I am wrong on any of the above speculation.
Thanks! I'm new to the amp/sub thing and you will not hurt my feelings if you tell me I have it screwed up.
