)Docmallory said:So, it looks like the factory sub has amplification from both front and rear amps, right? So, if I remove the factory rear amp, those speaker wires to the sub will still be running through the front amp.
Docmallory said:Hmmm, that's a bad thing if my plan is to run those wires to an upgraded rear amp, correct? More noise?
Docmallory said:Go to post # 2 in this thread and go by everything Bear says EXCEPT wires 3 and 4.
3 (yellow) should be left negative
4 (black) should be left positive.
If you look at Bear's scan, you'll see that "RL" on those two wires mean "Rear Left", and the R doesn't stand for Right.
Ok here are the pages from the FWD. Hopefuly you can all see them.
I would start by making sure that the red/black wire is properly connected the head-unit's amp turn-on wire. (and that it has 12V)Trying to install a new powered sub in the stock location but it’s not working. I followed the above wiring description. In trouble shooting I Noticed that the red/black is only 8 mV and crutchfield said it should be 12V. Also I’m running an after market double din unit and my rear ceiling speakers are working. Also I’ve by passed the front factory amp. Any thoughts on where to start?
