I hate to cross post but am not getting a lot of views in the electro forum so here goes:
Recently acquired a 1965 FJ45 (bone stock) and decided I need some tunes. So I added an AMP under the seat running to 2 speakers behind the seats. Plug in my IPOD and I have tunes! Problem is, when I hit the turn signal, brake pedal, or any draw it lowers the volume (for 1/2 second) like it's going to cut out then immediately back to normal. But only the first draw... so as the turn signal is switched it cuts then stays normal even though the blinker is blinking. As I switch the lights it cuts then stays normal with the lights on. Running or not with the ignition "ON" it's all the same.
Amp is wired right to the battery with fuse and large gauge wire with a switched power to the fuse block. I believe there's a good ground to the amp as I have jumped to the battery for ground to test that. New OEM fuse block.
EDIT: Oops... forgot to add this too:
When I first turn on the key the music plays fine through the first couple of initial loads (say two to three blinker on and off's) then the volume lowers on the fourth and it gets progressively worse. Same thing with the rig running.
Original thread here:
https://forum.ih8mud.com/electronic-toys/265373-amp-question-65-a.html
Thanks
Thanks
