Hi, I am a new member from Belgium who recently bought a BJ40
It has some work on it like the gauges that don't work, and I found out the senders just weren't connected.
Now i pulled the instrument cluster out to see whats going on on the back side of it, but I forgot to disconnect the batteries.
I touched the firewall with the ammeter connection on the far right side of the cluster and it sparked.
The ammeter was not connected tough.
Now guess what, nothing works anymore, doesn't crank, no lights, nothing. Checked the fuses and all were good. is it possible i fried some wire or the instrument cluster itself ?
I hooked up a direct live wire from the battery to the AM terminal at the ignition switch and this way everything works and i can crank the motor and everything.
So there's 2 live wires going from the starter motor in the cab. One goes to the glow relay. The other one splits in 2 and one goes to another little box left to the glow relais, don't know what this is ?? And the other one was connected at the back of the instrument cluster, NOT the round plug. Don't know what that is for either.
I dont have 24 volt at the AM terminal, and no 24 volt at the round plug of the cluster neither.
Anyone know where I should look? Or what to do with this ?
Thanks,
Niels
Thanks,
Niels
