ccasteel
So I bought one of these fantastic Amaurer gauge sets and brackets used because they are NLA.
Aftermarket (even mechanical) gauges into STOCK cluster!!! It's used and the wires were not connected. I replaced the wires in the connector to make them color correct. Now I need to figure out which wire goes to which connector. Who's done this that can help me out?
Working my way around the barrel connector
1. Ground - white/black pretty straightforward ground to cluster
2. Oil pressure sender - It's a 3 post gauge and the middle is ground. Which one should the yellow/black attach?
3. +12v from ignition - blue/red I haven't got a clue. (Voltmeter?)
4. Fuel sender - Another 3 post gauge and I'm supposed to skip the middle. So which one for the yellow/red?
5. Water temp - It's a 3 post gauge and the middle is ground. Which one should the yellow/green attach?
6. High Beam - red/yellow straightforward to the light I'm using for the HB indicator
7. VSS - blue/white skipped
8. Turn signal Right - green/yellow straightforward to the light I'm using for R turn signal
9. Turn signal Left - green/black straightforward to the light I'm using for L turn signal
10. Meter Pilot Lights - red/black goes to the positive wire on controller for the EL wire light
Bonus Question - What do I connect to the voltmeter?
