- Joined
- Oct 21, 2010
- Threads
- 20
- Messages
- 372
- Location
- Carson Valley, Nevada
- Website
- troutadventures.org
AFAIK, the FCC generally restricts radio products to a single license category... so you have commercial radios for commercial frequencies, amateur radios for amateur frequences, etc.. However, as some commercial frequencies are adjacent to amateur frequencies, a manufacturer can design one platform that can support both and just create two products from that platform where something, such as firmware, limits each product according to the FCC rules. And with some of these, there are software hacks that open an amateur radio up to other frequencies.Yeah I think the majority of the attending members are hams. Most of us newer licensees just need to use it more and become comfortable with it.
I do have a question for those more experienced. I am considering a DMR capable radio...
Anytone AT-D578UV III Plus DMR Tri-band Amateur Mobile Radio
Anytone AT-D578UV III PRO VHF/UHF DMR Mobile Reservationwww.gigaparts.com
It says it is "commercial" but has an amateur mode that appears to hobble it at a lower wattage limit.
My question is whether you guys think the radio can access amateur frequencies in commercial mode with the higher wattages, or if it is one or the other only.
To be clear I have zero interest in messing with commercial of government frequencies, I just like the high output dual-band and DMR capabilities at the price point of this unit.
Edit: to actually answer your question, my guess is "no" (assuming no hacks). I would think that when the unit was configured for commercial use, it would be limited to frequencies allocated for commercial use. Likewise, when configured for amateur use, it would be limited to frequences allocated for amateur use. That is, regaardless of band, the radio should only be able to transmit on the frequencies of the license the user is expected to hold. Typically users that holds both commercial licenses and an amateur licenses will have separate radios for each license usage.
Note: I note that when someone uses the term "band", they may not be referring to the whole band.. but instead to particular license category's frequency allocation within that band. That is, this radio (in amateur mode) could be called a tri-band 2m / 70cm / 1.25m ameteur radio, meaning it supports amateur license frequency allocations of those bands.
In response to the DesertLake's GMRS follow-up...
For club comms, I think we should continue to use 2m HAMs for primary comms, especially between trail leader and trail sweeper.... and encourage others to get their HAM license and minimally a cheap handheld. Even if one later upgrades to a mounted mobile unit, having a handheld is quite useful (such as for spotting others).
