1994 fzj80. Old harness crumbled. Need help identifying which wire is which.
The 1994 Toyota EWD is available in the resources section. Free to download.1994 fzj80. Old harness crumbled. Need help identifying which wire is which.
actually... i can figure it out based on this post.. thank youPost #24 might give you he info you require. (Assuming 94 wiring is the similar to later cruisers.)
Upgrading stock alternator to 130/150 amp
You know, I'm really not picky, either one of those will do just fine. Just in case I still have brackets and connectors available. As soon as it gets a little warmer I probably will make another batch since I still have the jig on the machine. Just PM me. Billforum.ih8mud.com
When you make statements like that it makes me bang my head on the desk. The EWD clearly shows the 3 pin connector and associated wire colors. Page 52 in the CHARGING section. The next page (53) shows the connector and pin assignments.Thanks guys, i checked the post, and the wiring diagrams, but its not helping my situation
The pigtail on my wiring harness had a Black wire with white dots, Black with green stripe, and yellow. yellow was (IG) , black with green stripe (L), Black with white Dot (S) I ended up getting a battery to reinstall so i could identify the wires with a multimeterWhen you make statements like that it makes me bang my head on the desk. The EWD clearly shows the 3 pin connector and associated wire colors. Page 52 in the CHARGING section. The next page (53) shows the connector and pin assignments.
