My original style alt. set-up with separate voltage regulator is no longer keeping my battery charged.
I've got a new Yellow Top with winch, ARB compressor coming off of it along with a 6A MSD multi spark and DUI distributor.
My alternator reads 11 volts and the lights, turn signals dim when the radio and defrost/heat is on.
What should I do?? Replace with factory style alternator and retain external voltage regulator or change to something else?
I've seen the FAQ on GM alt's, but did see what you guys thought about the particular units vs. oem.
Thanks
Thanks
