Alternative tire carriers (6 Viewers)
long beach
Probably a stupid question, but has anyone tried attaching a tire carrier to the back door of a GX470 with a tire carrier that was made for another vehicle?
some people have been welding a post to their rear frame, cutting a hole through the bumper for the post and using a Jeep swingout for about 400-500 bucks. i think @racwerx did this.
The door isn’t all that strong so I think this is asking for a ruined door.
overseas the prados have the tire mounted to the door. theres a couple shops in the USA that make a kit to do this, but i cant remember their name.
Rampage Offroad Jeep JK single arm over sized tire carrier. One hand operation, opens with the rear door. No issues. Should have the new spacers dialed in during Christmas vacation. Got lucky on a open box at Amazon for around $78.
Yeah, I have a Becky. No way would I want to try to gin up my own that’s just bolted to the door skin.
How did you get that tire carrier on there? Did u do it yourself, it looks really good.
What size tubing did you use for the main member?
i am planning something very similar, same latch, but I am using a single shear pivot.
2x2 3/16” for the swing arm, 2x3 1x4” for the frame mounts. Overall it’s pretty solid. I used the 4xinnovations latch and hinge. Here’s a pic of how I set it up if that’s helpful
2x2 3/16” for the swing arm, 2x3 1x4” for the frame mounts. Overall it’s pretty solid. I used the 4xinnovations latch and hinge. Here’s a pic of how I set it up if that’s helpfulView attachment 2868743
You definitely get more strength from connecting the tire carrier across the top like that. I was planning on 2x3x3/16 for the main beam and frame mounts. Awesome job 👍
Have any of you with the custom swing arm on the frame considered attaching the tire mount to the back door, like the Becky or jw off-road? That way, the tire would open and close with the door (convenience) and be supported underneath by the swing arm attached to the frame.
i would imagine you would need some sort of sliding track for the door mount, as the supporting swing arm pivots from a different point than the door itself does.
  • Like
Reactions: GTV
It's been done. Just need an arm. I will probably try to build these one day... as they combine the convenience of the JW/Becky with the strength of a bumper mount.
Build it and take my money!!!
