Builds AK HJ-75 (4 Viewers)
I'm with AndrewHadji on this one. Coldtaco, you've given us a photo of the clearance of the U-bolt ends, but that doesn't make it easier to tell if there's a potential issue in that area. Could you provide your opinion please? Yes, because i find those flipped U-bolt leaf spring items rather attractive.
you could cut the studs to just above the nuts, yeah?
Ah, i see. Thank you, gentlemen. Food for thought, and now to chew on it. Cheers!
Another just because.
Replaced the recessed part of the air cleaner outlet. Probably gained 0.1% hp :-)
Wondering why you went with the two different frame to axle brake hoses?
2-2.5" lift and higher should go with the 96940-34705's at both ends.
