Yep thats what i used.The guy on Facebook responded. Here is what he used. I’m ordering and will document.
I agree with you. I don't see how using the T would throw a code. When the throttle plate opens, the intake applies vacuum to all those lines plugged in to the side of the intake pipe, just like it would with the factory intake resonator. I used a T also and tried to route the lines so there was minimal rubbing or bending of the lines.I'm really not that happy with how the T-connector connects to the lower air line, I hooked it up with what i had, It's the lower TOY Line, It has a Factory Bend in it and the T i used is bending it up, which in time will split the line. So it's either cut the lover line so that bend is out or add a Elbow or a purpose bent line. I just wanted to make sure no codes got thrown. The Custom Fab guy i talk to from K&N told me that it wouldn't work. For the past month i've been pulling 6K to our land fill every 3 days with no codes, """"""SO THAT SAYS ALOT ABOUT THE CUSTOM FAB GUY AT K&N KNOWING HIS PROPUCED THAT HE SELLS.""""""
I just broke a nipple off mine, was going to go outside and measure to see if the Tundra one fits and bingo, this pops up in the threads. AWESOME!The Tundra/Sequoia intake pipe is not a perfect fit in the 100, but it will fit. I installed a junkyard Tundra/Sequoia intake pipe after the original developed a crack.
I assume the aftermarket part could be made to fit as well.
Please update us this coming summer on your current cai setup. I remember running a similar setup on my 4AGE 20-valve corolla about almost 2 decades ago and during extreme heat my engine would suffer from engine heat soak on prolonged idling.I did the entire K&N mod for my '05 LX. I removed the mass airflow sensor from the original intake pipe and attached it to the K&N. I attached the K&N air box and have noticed that it now sounds like an American V8 but I have not seen any indication of increased HP or fuel economies of scale.
She did fine last summer but I'll monitor again this summer too.Please update us this coming summer on your current cai setup. I remember running a similar setup on my 4AGE 20-valve corolla about almost 2 decades ago and during extreme heat my engine would suffer from engine heat soak on prolonged idling.
You'll get not a whit of horsepower from it. It might come with a sticker, tho.Since we are talking about air intake enhancements, sorry if I have to ask here but I couldn’t find a definitive answer anywhere; anyone tried this on their LC/LX?
View attachment 2630809It’s drop-in type of “performance” filter by Mr. T, washable.
Not the T, the hole thing. Thats what the guy said at K-N,I agree with you. I don't see how using the T would throw a code. When the throttle plate opens, the intake applies vacuum to all those lines plugged in to the side of the intake pipe, just like it would with the factory intake resonator. I used a T also and tried to route the lines so there was minimal rubbing or bending of the lines.
My 17 year old daughter made me laugh after she made the trek to our friends' cabin in West Virginia, laying down the quickest trek time anyone has made up there to date I'll add, and yes, she's 17...You'll get not a whit of horsepower from it. It might come with a sticker, tho.
I don't see any way for it to cause a code. All the hose does for the engine is to supply a filtered-air source of vacuum for the passenger valve cover vent, the steering idle up valve, and the charcoal canister (maybe one other, I forget?). If there is vacuum (which means the hose is sealed from intake to air box) those will all be happy.The K&N guy said the whole thing, as in the whole K&N intake tube would cause a code?
Where did you get the elbow piece that attaches to the throttle body?This is mine. Too much money for what it is. But I want to see what's going on down there. I had the pipe sitting.
Headers (exhaust system to 3” outlet pipes), high lift cams by TODA Japan (same with the 1UZ), ported intake and exhaust heads) plus strong valve springs will definitely give you additional HP if you’re going the Naturally Aspirated route.Unrelated but related, what’s the dyno gain on these various mods? Do headers/cams/heads make a significant enough difference to make them worthwhile?
