Tapage,
What I was referring to was a "larger cooling capacity", ie more rows, and possibly thicker core if you cannot enlarge the length and width. I would suggest a thicker 4 row rad. I went to the triple pass 4 row desert cooler option on the US radiator. My new radiator fits into my original shell on the FJ/BJ mutation. Also make sure the air is being pulled through the without any leaks around the fan shroud, I use silicone rubber and closed cell weatherstrip to seal the fan shroud to the radiator. A very small area opening will cause a pressure drop on the engine side of the radiator and cause a loss of cooling airflow. Also check your fan clutch, if its not locking up at temp your cooling will be compromised.
