AHC leveling/lift, anything other than portals? (5 Viewers)
Tampa, FL
Title kind of says it all. anybody attempted to do a leveling kit or adjust AHC to level or lift vehicle permanently yet? Would like a level look, or eventually be able to run 35’s without having to install Portals.
Just know when you install leveling kits on any trucks, when you load cargo or pull a trailer, they will have a more pronounced ugly squat stance and may cause understeer (when loaded heavily). They do look good unloaded.
Photo not mine, i just found it on the web,
Just know when you install leveling kits on any trucks, when you load cargo or pull a trailer, they will have a more pronounced ugly squat stance and causes less steering too(when loaded heavily). They do look good unloaded.
Not sure that would be the same here, as the AHC auto-levels. So if I lifted the front to level it, recalibrated, then when a load is added, the AHC would lift the rear again...
Thats a maybe though because you only get so much up and down.
What you probably could do is adjust the height adjustment arms so H1 is H2 and N is H1.
Doubt you would fit 35s without it being stuffed? Maybe 295/70/18 Recon Grappler or 315/70/17 Goodyear? Little smaller and not super heavy.
On a side note I bet that little 250 cruiser was an absolute joy to drive with that oversized heavy tire combo and travel trailer!
Oh, that little 4 banger must have been screaming (literally) for help on inclines. I am sure the owner would say otherwise though... :rolleyes:
And on any scale those Falkins usually rate as absolute heaviest.
Transmission was definitely crying.
That won’t help you fit 35s and you certainly don’t need portals to do so.
Have you tried adjusting the height sensors? On the 100 and 200 series AHC trucks there are height sensors at each corner that you can adjust and set the neutral ride height about 1-1.5” higher.
If you have techstream there is also a height offset utility.
Someone here has already done the sensor lift, I just forget their handle.
Otherwise Long Travel AHC should similar to the 200 vis-à-vis @TeCKis300
I’ve done it… nets 1” of extra lift. I suppose you could adjust just the front to help level it.
Lowering the rear causes the system to bottom out in L, which raises the vehicle back into N so don’t do that.
The arms are easy to adjust so it’s simple to play around with it. Just loosen the bolt on the adjustment arm and slot it all the way down to lift the truck.
Did you need an alignment after doing this?
No, but I’ve been thinking about getting one. Done it with all my other trucks after lifting even though this was only an inch and nothing feels off.
I’ll probably have it done in h1 since that’s how I normally drive around.
So essentially only lower the front adjustment arms is what you did?
Does this increase the height of H2 (max height) as well?
Cool so to be clear, put all 4 all the way to the bottom to net a 1” lift? Any downsides to this?
Correct… just loosen the nut and slide the bolt to the bottom of the bracket and then tighten it back up. No down sides.
Bringing back this post about
Bringing back this post...thanks for the picture, got some questions. I'm looking to just level out the front of my AHC. When adjusting the arms it looks like you can adjust it to any position in the bracket, or do you have to slide it all the way? I haven't looked at mine yet, so this may be a dumb question, but does it need to be in any certain height mode when doing the adjustment?
And you said you've found no issues so far...so if I were to raise the front an inch, it would stay that way in all modes, so even when it automatically lowers at highway speed, it stays level right? And essentially, if you decide to do all four, you get a "free" 1" lift. Have you tested to see if it still raises up in 4lo?
Some helpful tid-bits:
