Message/Reply from Tech:
And he may be correct.
If the nitrogen bulbs are ruptured and you continue working the AHC it would eventually burp out the gas and replace with the fluid in the bulbs.
I can assure you fluid can bypass the lower seals and eventually leak from the top.
Keep driving the way it is and it will get there.
You can try new nitrogen bulbs. But in my experience with that many miles you are putting a band aid on a very worn suspension.
Dollars and cents.
The bulbs/globes/spheres/accumulators/gas springs (the devil is known by many names) do not have a top from which they can leak, and no "lower seal" other than the o-ring preventing the fluid to leak out. They are sealed chambers with only one opening.
Even without knowing you ahc pressure, it looks like your globes are out of gas, which means that the nitrogen (which is the main ingredient in air) has leaked out through the membranes in the globes, making the fluid foamy, and eventually making its way up to the reservoir and merging with the atmosphere there. This happens eventually with all the ahc equipped cruisers.
When the globes are "flat", the car should not be driven (at speed), as it is no longer roadworthy. The movement of fluid in and out of the globes is what make it possible to dampen the suspension movement (shock absorber function). Without gas in the globes, there can be no movement of fluid and therefore you have no shock absorbers.
The suspension parts are normally worn on an old car lacking maintenance, but the ahc components normally last longer then other suspension components. The first parts to require replacement are normally bushings, ball joints and coil springs. The gas springs (globes) normally last longer than the coil springs, and the rams that look like shock absorbers last much longer than normal shock absorbers. But, if you don't change the coil springs in time, and tighten the torsion bars, you will put more and more load on the globes and shorten their life span.
That said, there are many parts of the ahc/tems system that need checking, and if you are not comfortable with maintaining an ahc equipped cruiser, it can be a daunting task. The common way of diagnosis at a dealer's workshop, is to change out parts until everything works, which can get expensive. You really need to get hold of TechStream or some other code reader / tester which is compatible. You can check the heights and pressures and from that find the state of your springs (the state of the globes does not affect the static pressures and the functioning of the height control). You can also check the state of your 3 height sensors and their linkages.
It is more expensive to maintain a cruiser with ahc than one with conventional suspension, mainly because of the diagnostics and lack of understanding of the system. But if you do it yourself, and can afford to spend time on it, it can be affordable. I do like the ahc, but if I was going to drive across Siberia, or Africa, I would think twice about going with ahc.
