After 24 years, 410,000km with a BJ60 in canada and 4 radiator rebuilds, I found OEM were too expensive and hard to locate, and NO success in aftermarket suppliers whatsoever. I finally found a shop which does excellent custom radiator rebuilding. AER Radiators in North Vancouver BC (604-988-4480) and ask for Gary. He rebuilt my rad last year, put in a 4 row core and did a brilliant job of triple pass full depth soldering, he even wanted me to watch him do the assembly, so no issues with quality!!! It's tough as nails and cools like a demon. He has even made new sheet brass top and bottom headers from scratch for other cruisers. Not cheap (500cad), but much better than stock, and a really decent guy to deal with.
I'm tossing around the idea of replacing my tired rad...I do notice my temps getting up when I'm towing my M101...I have a stock rad, what say the masses, aftemarket aluminum or old school 4 core?
What are your EGTs. Your rad may be fine. You may just need to drop a gear and be satisfied with the lower speed when towing. I see overheated vehicles all the time that are towing - even in the winter. Almost every time when i ask about what gear, either I get a blank stare or "I didn't know I couldn't tow in overdrive". Also, if its an auto always add an external tranny cooler of the proper size and disconnect the transmission lines from the internal rad tranny cooler. It'll keep the heat down (coolant and tranny) and extend the life of your tranny.
What are you doing to the poor thing? Until I installed A/C in my '82 BJ60 I was running the original 3 core rad. I probably had 400,000kms on it when I pulled it for the 4 core required to run A/C (it still was not leaking at that point). Most of the fins were gone for the lower 3-4 inches.
So I need a rad for my 85 BJ73 and from doing a search is it true I can just order up one from toYota Here in BC ??
Thanks
FX
Thanks
FX
Ha you even write with a french accent ..Just find the bill in my paper... :
BJ70 radiator 16400-58310 : list price 497.00 ... nov. 2006
HTH
