I've used a wire taped to the cable/connector to pull it through from the other end while massaging the boot. I wouldn't cut it if I were you.
I am definitely going to try again. Gotta head to the hardware store anyways so may look to see how much a small wire tape would be. I know people have used large ziptie/cable ties in the past, I was using an old metal hanger. Just need to be more careful in the middle section of that wire loom/boot.I've used a wire taped to the cable/connector to pull it through from the other end while massaging the boot. I wouldn't cut it if I were you.
Easiest is to pull the tail light assy (2 screws) and tap the reverse light wire there. Doing one wire and "Y"-ing it near the passenger seat should work, yes.I'm looking for both ideas and clarification. I'm installing a backup camera in a non-nav 2000 LC using an Alpine deck (ilx-650) that has an RCA input on the head unit pig tail. Since I was running RCA cables to the amp under the passenger seat anyway, I ran an extra RCA connected to the head unit harness camera input, so in the next couple days when I get time I can run the camera RCA to the passenger seat and not have to open the dash again. So... I need a reverse wire for the head unit harness (so it knows when to switch to camera mode) and another reverse wire for the camera, I assume to power the camera for when it is needed or backup.
My head unit reverse wire ideally needs to be near the head unit or one of the front seats. Near the passenger seat is ideal since I already have the seat out and some of the panels in the area removed anyway. Where do I find it and how do I recognize it among all the other wires.
My camera reverse wire could be by either tail gate (haven't decided whether I'm going upper tail gate where the factory camera is on the '03-'07 nav LCs was located) or lower tail gate) or I could run a revers wire all the way to the passenger seat area along with the RCA plug. If that's the case, would it work to connect both the head unit and the camera to the same reverse wire? Or for a shorter run, where would I find the reverse wire in the tail gate? I'm sure it must be connected to the reverse lights.
If one wants to avoid drilling the tailgate, this is a good one to use (this is the type I have). Near the end of the thread there is an adjustable one as well, should someone want to go real fancy
There are also some great advice on installing in the thread (like using wire pulling lubricant when pulling the connector through the grommet)
Back-up camera with intelligent tracks
I found this on AliExpress and ordered one ... I am pleased with the fitment and results. It works with a gyro in the camera assembly to detect the yaw and predict where the vehicle will track in reverse. The unit replaces one of your license plate lights and has a slot to insert your...forum.ih8mud.com
Damn - I should have looked at my backup camera details earlier.
The Alpine I'm using utilizes a long common lead that brings the video, ground, and reverse or accessory wires together to the front of the car. The good news is it's a fairly sleek package that should make fishing the wire through to either tailgate easy at least relative to bigger packages. The bad news is I don't have a choice of tapping into the reverse lights in the rear without running a second, dedicated reverse tap all the way from the front to the back along with the camera wire.
It's got to be easier to just find a reverse wire around the front passenger side kick plate. Anyone know where that might be? There are several large size wire bundles... I can't imagine a reverse wire isn't in there but I'm also not super excited about digging in there to cut wires. Is there something on the driver side that is easier to locate?
Anyone have the EWD for a non-nav 2000 LC handy? I'm hoping there is an accessory power in one of the OEM amp connectors? The two connectors at the factory amp location are S6 and S7. From a post on another forum, I've already soldered pins 2 and 9 from S7 together as apparently those are accessory lines in and out, and if bypassing the factory amp, failure to tie those pins together will leave the accessory wire from the factory radio connection inoperative. I suppose I could cut that solder job and do a 3 way connection with S7 pins 2 and 9 plus the accessory/red wire from my camera hookup.
There is... in one of the linked threads in the original post, there is a post about tapping into the reverse wire at the drivers kickpanel. There is a lower, separate small block of wires that you tap into a Blue with Red strip (I think, confirm with thread) and that becomes the trigger wire for the backup at the stereo.
Answered my own question... on my 2000 LC, the wire is red and black, not red and blue. I think i found it in a couple locations, but the one I'm going to use is by the ECU behind the glove box. It's the second pin from the bottom on the second connector from the bottom. I confirmed it was reverse by removing the connector from the ECU, sticking a paper clip in the connector at that pin location so I could connect a voltage meter, and then checking the voltage change as I put the car in reverse. I wasn't sure at first as the voltage meter was picking up a small voltage (I think it was 100-200 mV) when the lights were turned on, etc., but the voltage rose to 11.3V only when the car was put in reverse.Thx. Easy question ... I found that thread and diagram. The reverse wire is pin#12 in the iD1 connector by the driver's kick panel, which is labeled as "R-B" wire color. Before I start cutting and testing, is R-B Red-Black or Red-Blue? The comment above says Red-Blue, but what appears to be the #12 wire is Red-Black. One of the photos I saw of a reverse wire back by the tail lights is also Red-Black (not blue).
What's the best way to test a wire without cutting it?
