There is a thread where a user outlined his steps, in a very minutely detailed way..
As Chris mentioned, don't bother taking your wheels off. Take a deck of playing cards, and insert them in the gap between the rim and the wheel. I stuffed wrapping paper in the spaces behind the rim and then rattle can painted with 4 coats of primer, two coats of paint and then a gloss coating. It took time, but the results work ..
My real issue is these shiny chrome wheels Any suggestions on what would be easy to cover the wheels while on the 100, and look good and be durable. Would the primer then a dull black enamel paint be a more durable longer lasting solution? Plan on doing this myself. Thanks
Can I just take the wheel off and plasti dip with little to no prep? Suggestions?
I took the wheels off, cleaned them, and sprayed two light coats, then 3 heavy coats.
Not sure I understand the love of plasti-dip.
Why not just paint them? Clean, scuff, prime, paint. Looks great, will last a long time and easily touched up.
To the OP, if you decide to paint the chrome wheels, I'd do the "scuff" step above a bit more thoroughly. Maybe 320, then a red scuff pad, then prime. Need to cut that chrome a bit to give the primer something to grab.
