I did, out of budget unfortunatelyCheck out SDHQ. They have quality made terminals and lots of other things.![]()
SDHQ Built Complete Billet Battery Terminal Kit
SDHQ'S Complete Billet Battery Terminal Upgrade kit is designed to replace and protect your vehicle's OEM battery terminals. These blocks distribute power for your accessoriessdhqoffroad.com
IMO a fire is pretty unlikely to occur on a GX with a stock wiring system. If your GX has hack-job wiring, a fire could start anywhere on the aux wiring. However a fire can also start if you are welding/cutting/griding on the vehicle while working on it (I was welding LCA braces on my rig recently and managed to catch Fluid Film inside the frame on fire). Aftermarket electrical accessories themselves (fridge, compressor, etc) would also seem to be at a risk of catching on fire.for those with experience, where do vehicle fires typically start? where do electrical fires usually start, and where do fluid leak fires usually start?
I have a fancy Element fire extinguisher mounted on the driver door, but do not believe I have trained enough reps should a fire occur.
"Purchased another variation 2 times" hahaHere is the one I have. The marine version fits better on my DS seat mount than the auto version, so that's what I got.
This is the mount I have. I did have to drill a couple more holes in it to mount the marine extinguisher.
About $80 all-in for both.
What are your future plans for electrical? If those are the only items you plan on having, then you can just run it as is with some minor tweaks. But if you're planning on adding more accessories and things like DC/DC charger and solar, the wiring can become overwhelming and it makes a lot sense to start with a distribution box .My GX460's auxiliary wiring situation needs some attention, partially because it's just a mess and partially because I want it to be easier to work on, track down issues should one occur, etc.
Currently, every auxiliary part going to the battery is a bit of a hodgepodge:
- Winch wired directly to the battery, with a large inline fuse
- Driving lights, with a large inline fuse
- GMRS unit with a small inline fuse
- GMRS antenna with small inline fuse
It looks like this sans battery:
I'm in analysis paralysis mode about how to remedy the situation. The options seem to be fuse block, bus bar, junction box, junction block... truth be told, I'm in over my head. A friend is recommending adding bus bars for positive and negative terminals, but he's also running an Auxbeam which is above and beyond what I have any need for. Maybe just a bus bar is the easiest path here? A way to incorporate the fuse into the ordeal would be great but if it adds complexity now might not be the time/place for me to do that much messing with things.
Anyways...
Requesting assistance from the GXOR hive. Thanks everyone.
I've seen a couple of car fires and both of them have been engine compartment, so probably not electrical more likely fuel leak or oil leak. I would think stock wiring or properly fused wiring has very little chance of starting a fire because it would also need to have something flammable right next to the short to catch fire. I have heard of dry brush getting caught up around the exhaust and causing fires.for those with experience, where do vehicle fires typically start? where do electrical fires usually start, and where do fluid leak fires usually start?
I run my HAM radio directly to the battery (with fuse of course) so when I'm parked and need to monitor the radio for whatever reason, I don't have to have my AUX on, just the radio.My GX460's auxiliary wiring situation needs some attention, partially because it's just a mess and partially because I want it to be easier to work on, track down issues should one occur, etc.
Anyways...
Sealant should hold these things in place if you do not want to drill. I have one of those big switches on top the main fuse box for the past 2 years and lots of rough off road miles.After a ton of research and analyzing current/future needs, I think I settled on a solution. With cost and ease of install being front of mind, here's what I'm planning.
This (very primitive) bus bar -- 300A should be more than enough since the winch will be wired directly to the battery. Will likely mount to the top of the fuse box and do some kind of sealant around every hold I drill.
Amazon.com: 300A 12V Bus Bar with 6 x 3/8" (M10) Studs & Cover, Power Distribution Block for Marine Boat Solar RV, 12 Volt Bus Bar Terminal Block Kit with 4 AWG 1/0 & 8 AWG 2/0 Copper Lugs : Electronics - https://www.amazon.com/gp/product/B0G7Y6VH6G/ref=ox_sc_act_title_1?smid=AURES3XE1VYF1&th=1
and this to prevent any potential parasitic drain
https://www.amazon.com/dp/B00445KFZ2?tag=ihco-20
I was considering something like this instead of the junction blocks, but everything I'll be hooking up (lights x2, GMRS) already has a fuse in-line so I'd be doing extra wiring that I really don't want to do. So seems unnecessary?
https://www.amazon.com/Blue-Sea-Sys...sea&qid=1773674090&sprefix=blu,aps,913&sr=8-7
Thoughts?
Good call. So I'd only be using the bus bar for fog lights and the Lightforce lights for now.I run my HAM radio directly to the battery (with fuse of course) so when I'm parked and need to monitor the radio for whatever reason, I don't have to have my AUX on, just the radio.
Good to know, thanks. Pardon my noob-ism when it comes to wiring here, how does the switch actually get wired into the winch wiring? Did you have to add any extra wiring? Or just wire the winch in there and through and out? (Learning about wiring as I go)Sealant should hold these things in place if you do not want to drill. I have one of those big switches on top the main fuse box for the past 2 years and lots of rough off road miles.
Thanks, good stuff. What did you use for the negative terminal side of the connection?yes, I had to get some additional wiring. I used 2 awg https://www.amazon.com/dp/B0BSB29XYF?tag=ihco-20 from the battery to the switch, then wired the winch to the switch. Disclaimer: 2 awg is not rated to handle 350amp continuous current my winch draws at max, but 1. it was the only wire I was able to bend, 2. it was thicker than the wiring the winch (superwinch 10k) came with, 3. it' almost never draws 350a- only . 4/0 awg would be the properly rated cable for 350 continuous. you can find charts online, but what I see is that 2 awg can handle a 200a load for about 30 sec, then require 5 min of rest. Ideally, you use a thicker awg.
battery- short length of additional wire you will have to buy- switch- winch.
Absolutely agreed. That would also imply the cable coming from the winch is 4 AWG, which seems to be the case in that photo.@llm I am by no means an electrical guy, but 2 awg wire is significantly larger in size than 4 awg…& can safely handle a larger load than 4 awg.
I did mine a little different2' of the cable is probably more than enough right
