For Sale Additional Torque
Bay Area
Works on any Toyota. not sure how much hp this equates to - but seat of the pants - id say it feels like it worth 5-6hp if not more. 80 guys could likely use this more than 100-200guys...and anyone with a stock 60 or 40 series,,,,,,it pretty much doubles your torque. Aussie import.
How much are you asking? May end up being cheaper than the V8 swap everyone is doing these days...
This is classifieds. Post a price! :p
so this needs to go on my pants too actually add or notice any torque increase
How about if you put on two?
Im guessing u will blow a rear pinion with 2 of these. its a slippery slope with these.....too many and you need 4.88...then chromos/longfields and then u are going down the @nukegoat path to dana60s.....You know the drill.
I run 3
Do chicks dig it too?
Edit... Seller also said per PM that anyone woman to take a ride in a Toyota with this sticker
would exit with soaked panties.
I'm sold
Im sure that’s a violation of the warranty!
This much torque is claimed down under to be the cause of many a bent crankshafts on early 1HDT's. and yes toyota did void all warrantees if these were installed. Run at your own risk.
buyer has informed me he will be doing a fairly detailed install thread. * will likely be added to the faq*
I will be lining up needed supplies this week for install. I hope for 1 day of warm weather to get this job done.
I will also show before and after dyno results, along with MPG gain if any. When I have time I will cruse the town to show the
effects that this upgrade has to the ladies.
Thanks @bugsnbikes for the smoking deal on the best upgrade for my 1FZ-FE
A full day? Wow, this must be a :banana::banana::banana: job. Good luck. Hope you are prepared for what you're getting into.
Install is only 2:banana::banana: , but with all the additional torque....you need to make sure your ujoints, rear pinion nut are all up fo snuff. any play in the system and this amount of torque will tear your rear end a new sphincter.
Thank goodness I have a full floating rear axle. Be a shame with that amount of torque, a semi-floating axle break and start to protrude out like a prolapse.
