Adding a catalytic convertor to an H engine? Thoughts?
So Cal
A local school has an fj45 with a H engine in it. When my wife and I went to go look at it, all the smoke scared my wife. My question.... is adding a catalytic converter possible with these motors or does it cause harm? I know I would be looking at a universal option or is there something else?
Thanks
Smoke will not be removed via a catalytic converter.
Many reasons for smoke
1) Too much fuel
2) To little air
3) Worn rings/ valve stem seals/guides
4) Valve adjustment need
5) injection pump timing.
In Germany there was a kit for it, there a license plate can be changed and so boost economy and research (not in Netherlands...)
Also spoke to a mechanic that added AdBlue to old trucks, het said black smoke turns to white at startup. Maybe that is an option?
DPF Partikelfilter, Katalysatoren​
pdf BNOx SCR Baumot Twintec
It’s a Diesel engine;
where was the smoke coming from - tailpipe or under engine
what colour was it - blue, white,black
did it go away after it warmed up
An engine needs the right fuel settings to work and I think this would kill a catalytic converter pretty quick. Your best be it to ascertain why it is making smoke and go from there. Colour of smoke and how fast it clears is all important.
These engines were probably designed in the 60s, long before pollution was a concern.
Unless its a conversion, its proper designation is HJ45
Thank you guys for the response. It is black smoke at start up out of the tail pipe. So I guess it's just how it goes
It depends on how much black smoke. It could just need the injectors rebuilt, thats normally the first step. As they get old fuel tends to dribble, rather than a finely atomised spray.
Stay away and buy some new vehicle. H-engine will not suit to your wife. Emission devices would kill the H.
