Builds Add Power Locks and Windows and rear wiper to 24v HZJ75 Troopy
woytovich
Science...
Metro NY
I am on a quest to add power locks, windows and a rear wiper to my 1995 LHD HZJ75 Troopy. There are couple of other threads I've started on related topics that I'll link below but it is my intention to close those and document the process here... both to be able to solicit info and to (hopefully) provide the info necessary for others to do the same.
These have some info that I'll likely replicate as we go on:
Here are some pictures of the current state of wiring at the rear of my LHD Troopy.
Right side rear, a large unused plug:
The harness at the right side rear (I hope to find wiring for the rear wiper in here, and maybe the power lock wiring for the left side is here also). (The PO made a mess)
Inside the left (small) rear door (this will be where the power lock mechanism goes):
Pictures of the components I purchased for these installs.
Are these the connectors to the main truck harness? These are the only unused ones in the harness that I received for the power locks and power windows.
Other than these two small connectors that I believe are probably for power mirrors?
Hello,
These are some of the connectors.
These images are from an LHD truck. I suppose RHD trucks have a reversed setup.
Let us begin with the left side.
This is the connector for the power mirrors on the LH side. The RH side is identical.
This is the connector for the power windows, again on the LH side. There is a similar one on the other side.
This connector is for the power locks.
This is where the harness enters the door.
This is the ground point for the instrument panel harness. Note the fuse box in the background.
Hope this helps.
More to come.
Juan
Hello,
Some more photos.
This is the LH side power lock connector. It can be accessed from the tool bag compartment. There is a similar one on the other side.
This is the LH side speaker connector. Yes, there is provision for two speakers, one on each rear door. The camera had a hard time with this one.
Now with the RH side.
This connector is unused. I think it powers the rear speakers amplifier.
This is the rear window wiper relay. A close up of the connector is next.
There is provision for an amplifier next to the relay. This amplifier boosts the rear speakers.
More to come.
Juan
Hello,
Some more pictures from the rear right side.
Rear washer tank.
Rear wiper.
Rear lights.
Rear power lock.
Rear speaker.
Hope this helps.
Juan
