ACSD upper coolant hose block fitting removal
Greensboro, NC
Any thoughts on the best way to remove this fitting from the block? The upper ACSD water hose connects to it. I have the oil cooler cover without the lower water hose fitting (thanks @OGBeno).
I break off the nipple and use a punch that fits just in the remaining bung and pry it out.
Actually got a prybar from harbor freight and took off the point and cut length down so i can maneuver the bar around.
Use permatex freeze plug goo when you tap in the plug.
