- Thread starter
- #41
I understand.Paul, I meant the sliced open the main box in the engine bay to have a look at the relay on the underside, the 4 relays in there attached to the main board.
They cut it open and took the cover off, I assume to see the mag clutch relay. Someone suspected that before. There's an AC sig lock wire, it's blue that directly controls that, A47 pin 21 lock.
They probably also assumed replacing the screen board, and the ac amp would fix it. Which makes some sense. Without going down the fuse box-s rabbit hole.
So many diagnosed this AC system, and slicing open main engine fuse box is going deep. They left one securing screw out and the head of the other damage in main engine fuse box. Also some metal shavings in fuse box from striping the screws head. Could be they even replace evap. More than one replace the NAV unit and AC controller/AMP. They left low pressure cap off, bugger up the OAT sensor, etc., etc. Not one could get working. I'll bet around $5k was spend on this and then rig sold because of it. Then current buyer likely is in for $2K or more. WHY could no one get working? They did not consider bad windshield install. WATER LEAKS Something those who follow the 100 tech section of mud, know too well!
I buy rigs all the time with issues, I love those deals. Have two now sitting in my driveway. One is Graybeard in my signture, the other is GrayGal (not yet posted) I'll be writing up some day, very interesting story. These were both sold due to improper diagnoses.
In the 200 section there's a story of bad windshield install, that ended in rig being totaled. After countless hour try to diagnoses and fix, they (Toyota) gave up. Land Cruiser can really handle water well. Provided it does not get into side panels of interior or in the dash, those electronics are sensitive.
I think this one a good for the books. As it is first time I've seen RH J/B take out AC.
