AC hose fitting (Evaporator)
cruisermatt
Un-manufacturable
Supporting Vendor
Winter Park, Florida
Website
www.cruisermatts.com
Does anyone have a good part number for an AC hose end that fits the 14mm evaporator connection on the firewall? It seems to be an elusive one. The bigger fitting is just a standard #10 I believe.
I had to use the first 8-9" of the factory hose for that fitting when I did mine...had it crimped to one side of the service port.
(EDIT: #6 sized high pressure service port)
AC place (fittings and hose supplier) had nothing that matched.
- Brian
I cut the oricinal crimp off of the stock hose and took the tube and threaded fitting to the hose place. They can use a new collett to crimp the original into your new hose. That is the oddball fitting that is elusive. It can be found but using what I already had was the best solution.
- Brian
Don't have an original hose so that's not a quick option.
I have to think that Deo (@cruiserjunktion) up in Gainesville would have one for not much $$$ (???)
...if you can't find a fitting in the right size.
- Brian
I try to keep a few of these (new) in stock in 45s and 90s, since they are also used on the stock drier and condenser. Give me a shout if you need one.
