ABS/ VSC TRAC / VSC OFF
miami, fl
hello to all,
I was driving home today and all 3 lights came on in the dash. no codes pulled yet
Has anyone had this problem before? any input would be appreciated
I seem to recall something like this on my 2000 LC. IIRC it was a wheel sensor that got temporarily wonky (I may have gotten a little happy in some giant puddles during the mosoon season here in Ohio). Of course it also happened on my wife's 5 series and that was the Bosch ABS Unit (manufacturing flaw) BMW wanted to replace the unit for $1200 but there is a company in Idaho that reengineers them for $350. For the BMW it was plug and play. Good luck.
It's either the wheel abs sensor, or the biggie master cylinder/pump unit could be shot... Did you have any decreased braking ability right after. If not a good chance its one of the abs sensors.
I have had similar problems with my 2002 LX470. You should try and pull the ODBII codes to get a better idea of the actual problem. It could be a wheel speed sensor, steering wheel angle sensor, or VSC computer. I had problems when my front wheel bearings needed to be repacked. The front wheel would move slightly when jacked up. This threw off the speed sensor enought to throw a code.
Mine does this very occasionally, usually when its wet out. I think my brake light also comes on. There's a few threads on it. On mine, it doesn't effect braking at all. I haven't gotten around to getting it checked out yet.
Oz
drove the car today and when I drove over the raikroad tracks all the lights went off.
thanks for all the replies , when i check the codes I will post again
It sounds a lot like what happened on my '01 LX. Driving to work one early morning, same lights lit up. On the way back from work, stopped by Autozone, stuck an OBD tester on her, and no codes were thrown. Went by Lexus dealer next day, they also found no codes.
A bit of digging on the weekend showed a fried brake fuse...after spending an hour tracing the wires from front to rear, found the issue was a short between ground and brake wire...brake wire was broken and frayed, ground wire frayed. Location was in the tailgate harness where the harness crosses from body to tailgate. Crappy design allows the harness to make a back-and-forth u-bend between body and tailgate.
Correctly designed harness should have been parallel between body and tailgate for at least 3-4 inches so that the harness would twist instead of bend.
Fix involved splicing broken wire, re-insulating ground and brake wire, wrapping Kapton tape over wire bundle, convoluted tubing over that, and lacing take in 4-5 places to keep everything in place. Fix is good after around 60K.
Point of all this story is that electrical gremlins may cause dash lights to indicate weirdness without throwing codes.
OP's issue with intermittent dash lights might point to something similar.
hth
Steve
