A/T Oil Temp Light +ABS+Check Warnings on Dash
After driving 140 km/hr for two hours . suddenly above warning light apperes on dash board. I pulled a side and checked automatic oil gauge it was not low and not hot then decided to contiuned drive til home . then i noticed the lights disappers when I stoped. Nxet day same event occures. I DO NOT KNOW Why the ABS lights on also. any one have an idea.
FJZ80 95.
Yes all comes on same time
Automatic oil is changed with filter one month ago.
Check for voltage at the battery. I have seen borderline alternators do this to warning lights.
Also check the grounds around/under the dashboard.
Sounds more like an electrical problem than a trannsmission problem.
Alternator??
I type way to slow!!
Today , same light appers once at end of the trip. But when returned home no none of same light appers. tomorrow morning I will travel same trip and will watch and inform you all
Have you had any starter problems, or have you had the starter contacts replaced? Also, more on the vehicle history for cryin out loud...
DougM
loose battery terminal?
Why don't you try the diagnostic suggested?
More driving probably will not yield more useful information...
