A radiator question…
HDS
White Rock
I picked up a radiator from a local seller who said it was from a ‘60 series diesel wagon. After a year in storage I finally looked at it. There isn’t a filler point on the rad. Is this a closed system and the rad is filled from the outflow bottle? What gives? Am I seriously missing something?
Both HJ60 and HJ61 had radiator filler caps.. it does not sound like a 60 series radiator.. Photo?
Here’s some pics.
Regardless of what it is.. its well past its used by date. Certainly looks more 40 series than 60.
Oh well… bummer. It wasn’t cheap but I suppose I’ll chalk it up to a learning experience! Thanks for the input!
So this is going into an early FJ40? I would ask in the 40 series group.. any radiator that fits can be modded by any half competent radiator shop to put your outlets on the side you want them.. and dont forget the 3B thermostat housing can be rotated to point to the other side.
maybe that is a industrial /forklift rad?
lefthand steering 1985 HJ60 has radiator outlet on right side, filler on left, also the new rad had a different size cap (when you order something beware of that)
Any world of pain is a playground compared to my continuing meltdown over wrong parts:
Maybe the size is about what you need?
TOYOTA part # 1640068100 radiator
TOYOTA LAND CRUISER (_J4_) 4.0 D (HJ47_V) 08/80 bis 10/84 76 kW / 103 PS 3980 cm3 6 Diesel Geländewagen geschlossen
TOYOTA LAND CRUISER (_J6_) 4.0 Diesel (HJ60) 01/82 bis 12/85 74 kW / 101 PS 3980 cm3 6 Diesel Geländewagen geschlossen
TOYOTA LAND CRUISER (_J6_) 4.0 Diesel (HJ60_V) 10/81 bis 01/88 77 kW / 105 PS 3980 cm3 6 Diesel Geländewagen geschlossen
TOYOTA LAND CRUISER (_J6_) 4.0 Turbo-D (HJ61_V) 10/85 bis 12/89 100 kW / 136 PS 3980 cm3 6 Diesel Geländewagen geschlossen
TOYOTA LAND CRUISER Pick-up (_J4_) 4.0 D (HJ47_P) 08/80 bis 10/84 76 kW / 103 PS 3980 cm3 6 Diesel Pick-up
Length: 400 mm
Wide: 610 mm
Weight: 11,46 kg
Wide: 48 mm
Whenever I need to be sure I’m ordering the correct parts/fitment, I call Cruiser Outfitters (@cruiseroutfit ) and talk to the super smart people there and then place the order. They ship fast, and I get the right parts.
