Question: Where do the OEM transmission and transfer case breather tubes terminate? (I can't find them).
Thanks in advance.
The tranny and transfer case go to a clip on the tranny dipstick, I do believe.
Thanks in advance.
Thanks in advance.
Thanks.
I looked up and down the tranny dip stick tube today and there was nothing there attached to the tube. I did change out my starter about three months back and I do not recall seeing anything then. Maybe I'm blind. I know I'm farsighted so I'll get my reading glasses on and look again.
BTW, I looked through the FSM and found no reference to the breather termination points!
Hope that helps.
Question:
The rear end terminal for the diff lock actuator breather ends inside the tool storage area (driver side rear) and it has a Y shaped clear plastic terminal with a black rubber sleeve on one side. What is that all about ?
The rear locker actuator breather tube is black, in the rear wiring harness, comes out of the harness and terminates between the frame and wheel well about dead center of the left rear wheel. I extended it with vacuum line to the same place as the axle breather.
I looked at the driver side rear where the breather is supposed to terminate between the frame and wheel well. The wiring harness is there and a breather tube exits it but it goes through the rear most grommet where the trailer lighting wiring harness is and then terminates inside the tool storage area with that Y shaped clear plastic end I described earlier.
There was no termination at the frame/wheel well location (dead center above the rear axle).
Maybe the LX was terminated differently ?
Got me? Both my brothers trucks were the same as mine, '96 & '97 LC's?![]()
Here is a picture of the same breather end from George's write found at:
http://www.geocities.com/george_tlc/breather.html
Does anyone know what part this tube vents ? ($64k question).
The theory is that the clear tube is for the window washers on the ambulance door trucks, it's unused on our trucks.
They both mount to the tranny dipstick, just lookes at mine
i would strongly consider not using the stock vent flapper in any area where mud/dirt regularly gets slung. The stock vent will get mud in between the cap and body and cease to move(in open or closed position)- which can happen(ask me how i know) fairly easily.
Mine seized in the closed position from a combo of oil/dirt/mud and consequently sucked grease from the Birf into the axle--blowing the front pinion seal and puking the entire contents of the front diff gear oil til a few bearings went south.
