The cyclonic was one of the coolest things on my old 80s. The US-spec 100 panel filter was part of the "pussification" of the LC, IMHO!
I'm accustomed to monitoring the air filter gauge in our big rigs. You might find it helpful. ...
Put me down as well. That filter style was one of my most favorite things about my 80 series. It's a brilliant design.
Filter-Minders work great. I don't see the need for a dash mount, the under hood unit is plenty. They basically never move, so only need to be checked occasionally.
Agree, the cyclonic setup works great, the filters stay clean for a very longtime, even when used in silty/dusty desert conditions.
If the 100 series air filter setup is truly restrictive, that is a disappointment.All of the other Cruiser setups that I have played with are well designed/matched, even have the capacity to hold lots of dust before becoming restrictive.
I see this one on ebay for $34 delivered but I can't tell if it is "genuine" OEM. It looks OEM and it says Toyota with the correct part number but it is coming from HK.![]()
FYI: On a typical Nevada or Utah 2-3 week trip involving hundreds if not a thousand miles of dirt (during the dusty months of course) I typically need to replace my OEM filter element, or at the very least blow it out thoroughly, 2-3 times; no dorkel though.
Need or feel you need, how do you judge?
My guess is; most off roaders clean/replace them much more often than necessary, I know I did. At one time I cleaned/replaced mine a couple of times a year.
When I put the Filter-Minder on, the filter was a used Toyota cleanable, it had been cleaned a couple of times. Ran it for ~25K mi, ~2yrs, thousands of dusty trail miles, including Lockhart Canyon, Beef Basin, Rug Road, etc. The Filter-Minder reading never changed. Last year, got a good deal on a new filter, so slapped it in, same reading, will run this one out until the gauge indicates to clean it, it will be years?
This is on my 80 with cyclonic, the point is, they are very efficient. The pic is Rug Road, ~50mi looked like that. At the end of a day like that, the tuna can will have 1/4-1/2" (~1/2 a cup?) of silt in it. If it weren't for the cyclonic that silt would be in the filter.
I don't have a dorkel, don't see the point?![]()
Thanks! The seller did get back to me stating that they sold aftermarket filters. I'll steer clear and be sure I buy only OEM.I purchased from this seller previously when they were $14 shipped anywhere in the world free, so his price has gone up, just to see if they were OEM or not.
The two one-way rubber valves that I thought were to expel moisture I see are labeled as "dust relief valves" in the parts catalog. So the cyclonic box is partially self cleaning I suppose?I bet most of it would be in the honey-comb trap in the bottom of the air box. I vacuum a good bit out each time I check the filter.
Your point of knowing when to change the filter is well taken. I can't say whether or not the filter was not breathing at full efficiency only to add I swap the filter out when its caked with dust. The Filter Minder hoser pointed out and you are using sounds like the best approach for knowing when to change any air filter.
When i was looking at doing an airbox mod and pulled the main body away from the guard i "discovered" the other dust trap. I didnt know it was there. Anyway i pinched the rubber to let out the dust and it was full of dead bees, flies, butterflies etc and heaps of dust. I dont know that it self cleans though.
I'll keep an eye on both traps now that i have emptied them
Actually a before and after air restriction gauge reading would be a good way to test the value of snorkels, cyclonic air boxes, K&N filters, custom air tube and deck-plate air box modifications.
