- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,205
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
... I was surprised at the amount of junk I had on my evap, and I was expecting to get better tempsI had a bit of improvement but not much. ...
That isn't the way it works. Back to the heat transfer thing, the air gives up heat to the cooler (evaporator) during the time that it flowing through the cooler. A clogged cooler restricts/slows airflow, the slower moving air spends more time in contact with the cooler, so nets cooler air. Higher volume/faster moving airflow spends less time in the cooler, so nets warmer air.
When cooling a space (the interior of the rig) both volume and temp of the airflow is important. To a point, higher volume of slightly warmer airflow is better than a small volume of cooler airflow. If the coolest airflow possible was the most important, leaving the interior fan on low will accomplish that, but air circulation is also important.
